enable vpls fdb mac-withdrawal
This command has been replaced with the following command: enable l2vpn vpls fdb mac-withdrawal .
This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.
Description
Enables the VPLS MAC address withdrawal capability.
Syntax Description
Default
Enabled.
Usage Guidelines
Use this command to enable FDB MAC withdrawal after it has been disabled.
The following command enables MAC address withdrawal:
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
